Group: DynoMotion Message: 13379 From: daveymahomh600e Date: 6/23/2016
Subject: SnapAmp PWM Output Issues
Attachments :
I'm just finishing a new 2 axis machine build which uses 3 phase brushless servos and KFlop/SnapAmp.
For some reason I am not getting any motion when trying to move either axis and the Analog screen in KMotion shows no activity for the PWMs.
The motors turn during the initialization sequence (using the Write3PH () command), but not when trying to jog, move or tune. Autophasefindfast.c seems okay too.
Init file is attached. Any suggestions?
Thank you,
David.
  @@attachment@@
Group: DynoMotion Message: 13380 From: Tom Kerekes Date: 6/23/2016
Subject: Re: SnapAmp PWM Output Issues [1 Attachment]
Hi David,
It looks like your P I D parameters are all zero
Thank you,
David.
Group: DynoMotion Message: 13382 From: David Stevenson Date: 6/23/2016
Thank you.
Something else I just realized is the servo motors are 3 phase brushless, but they have 10 poles as opposed to the usual ones I use with 4 poles. Can the Snapamp manage these okay?
David.
On 6/23/2016 5:32 PM, Tom Kerekes tk@... [DynoMotion] wrote:
Hi David,
Thank you,
David.
Virus-free. www.avast.com
Group: DynoMotion Message: 13384 From: Tom Kerekes Date: 6/23/2016
Hi David,
That shouldn't be a problem.  The Autophase.s should determine
the correct number of counts per cycle regardless of the number of cycles (poles/2) per rev.
On 6/23/2016 5:17 PM, David Stevenson david.m.stevenson@... [DynoMotion] wrote:
Thank you.
David.
Hi David,
Thank you,
David.
Group: DynoMotion Message: 13385 From: David Stevenson Date: 6/24/2016
Thanks Tom.
I switched out the servos to the old style with the 4 poles and there is no way I can tune this setup. Today is the 3rd straight day for this and I'm no closer now than I was 3 days ago. I've read at least 10 different how-to-set-your-PID articles but the process doesn't seem to work here.
This is a brand new KFlop/SnapAmp and I have gone through the wiring at least 5 times. This is machine #10 with this design, but something is not right with this one. I even tried going back to an earlier software version.
Have there been any fundamental changes to the hardware that might need to be considered? All the power supplies check out okay and I have replaced the ribbon cables just to be sure.
Any suggestions would be greatly appreciated.
David.
On 6/24/2016 12:32 AM, Tom Kerekes tk@... [DynoMotion] wrote:
Hi David,
Thank you.
David.
Hi David,
Thank you,
David.
Group: DynoMotion Message: 13386 From: TKSOFT Date: 6/24/2016
Hi David,
There should have been no hardware changes from our end.
For a servo to work the commutation has to work correctly. Then the
Servo should hold position. Then you can begin tuning. Have you
verified any of the steps in order to determine what is going on.
For example you might enable the servo with:
#1 limited output to a small amount.
#2 infinite following error
#3 Only a small P Gain
#4 phase find and enable the servo
In this case the motor should act like a spring. The motor should hold
position and as it is forced away from target the torque should increase
up to the set limit. Then it should remain constant as the motor is
moved an additional few revolutions. If this works then most likely the
commutation is being performed correctly.
On 2016-06-24 13:43, David Stevenson david.m.stevenson@...
[DynoMotion] wrote:
> Thanks Tom.
> to work here.
> software version.
> Regards,
> David.
Group: DynoMotion Message: 13388 From: David Stevenson Date: 6/24/2016
After running the init file (attached) I don't think the commutation is working. There is slight resistance to turning, but not as much as I would expect. I re-ran the autophasefind.c to confirm the offsets, but that didn't make any noticable difference. The axis do show as enabled in the axis screen window.
Thank you,
David.
On 6/24/2016 5:53 PM, tk@... [DynoMotion] wrote:
Hi David,
[DynoMotion] wrote:
> Thanks Tom.
> to work here.
> software version.
> Regards,
> David.
  @@attachment@@
Group: DynoMotion Message: 13389 From: David Stevenson Date: 6/24/2016
Actually after bumping the P to 0.1 from 0.01 the motors are definitely servoing. Both axis though will allow a small (~20 degrees) rotation in one direction and then they lock up tight.
David
Thank you,
David.
Hi David,
[DynoMotion] wrote:
> Thanks Tom.
> to work here.
> software version.
> Regards,
> David.
Group: DynoMotion Message: 13390 From: Tom Kerekes Date: 6/24/2016
Hi David,
That would indicate incorrect Commutation.
Post your AutoPhaseFind.c program, the results, and your initialization program.
On Jun 24, 2016, at 4:58 PM, David Stevenson david.m.stevenson@... [DynoMotion] <DynoMotion@yahoogroups.com> wrote:
David
Thank you,
David.
Hi David,
[DynoMotion] wrote:
> Thanks Tom.
> to work here.
> software version.
> Regards,
> David.
Group: DynoMotion Message: 13391 From: David Stevenson Date: 6/24/2016
Here is the report for axis0:
REPORT
0 Position =  -1701 PhaseAngle = 0.583900
1 Position =  -3390 PhaseAngle = 1.097700
2 Position =  -1792 PhaseAngle = 0.581100
3 Position =  11310 PhaseAngle = -3.418900
Counts per rev =  -1689
Counts per cycle =  -3287
Counts per cycle (rounded)=  -3290
invDistPerCycle (rounded)= -0.000303951368
Commutation offset =  -1939
Input Gain Specified =  1.000
and axis1:
REPORT
0 Position =  -4998 PhaseAngle = 1.098700
1 Position = -21382 PhaseAngle = 6.098700
2 Position =  -4998 PhaseAngle = 1.071700
3 Position =  11386 PhaseAngle = -3.928300
Counts per rev = -16384
Counts per cycle =  -3277
Counts per cycle (rounded)=  -3280
invDistPerCycle (rounded)= -0.000304878049
Commutation offset =  -1099
The init file and autophasefind file are attached.
Thanks for your help,
David.
On 6/24/2016 9:19 PM, Tom Kerekes tk@... [DynoMotion] wrote:
Hi David,
David
Thank you,
David.
Hi David,
[DynoMotion] wrote:
> Thanks Tom.
> to work here.
> software version.
> Regards,
> David.
  @@attachment@@
Group: DynoMotion Message: 13392 From: Tom Kerekes Date: 6/24/2016
Subject: Re: SnapAmp PWM Output Issues [2 Attachments]
Hi David,
The AutoPhaseFind should rotate until it finds the index twice then reverses until it finds the index twice.
If things are working such that the motor is rotating based on the phase angle, and properly detecting the Index pulse, then the reported positions where the Index pulse was found should be equally spaced and at  similar fractions of phase angle.  Yours are not.
Do you know how many counts/rev your encoder should be?
Have you tested the encoder?  If you rotate one rev how many counts does the position change?  If you rotate back does the position return to the original value?
Most likely noise on the Index pulse, encoder not working, or index pulse being too short and being missed.
Attached is your AutoPhaseFind Program modified so it should rotate 4X slower.
On 6/24/2016 7:34 PM, David Stevenson david.m.stevenson@... [DynoMotion] wrote:
REPORT
and axis1:
REPORT
David.
Hi David,
David
Thank you,
David.
Hi David,
[DynoMotion] wrote:
> Thanks Tom.
> to work here.
> software version.
> Regards,
> David.
  @@attachment@@
Group: DynoMotion Message: 13393 From: David Stevenson Date: 6/25/2016
Thank you Tom.
The encoders are 4096 ppr which give 16384 per rev. They seem to be counting properly, but I think you are right about the index pulse having issues. I ran the revised phase find program and the results are not consistent. I will do more exploring today.
Thanks again,
David.
On 6/25/2016 1:03 AM, Tom Kerekes tk@... [DynoMotion] wrote:
Hi David,
REPORT
and axis1:
REPORT
David.
Hi David,
David
Thank you,
David.
Hi David,
[DynoMotion] wrote:
> Thanks Tom.
> to work here.
> software version.
> Regards,
> David.
Group: DynoMotion Message: 13395 From: David Stevenson Date: 6/26/2016
The commutation seems to be working okay now, but I still can't move the motors normally.
Will you please have a look at the attached specs for the servos and let me know if anything obvious jumps out at you as to why they are not moving properly? I know the SnapAmp voltage is only 80, but my understanding is this will just limit the max speed of the motors.
Thank you,
David.
Hi David,
REPORT
and axis1:
REPORT
David.
Hi David,
David
Thank you,
David.
Hi David,
[DynoMotion] wrote:
> Thanks Tom.
> to work here.
> software version.
> Regards,
> David.
  @@attachment@@
Group: DynoMotion Message: 13396 From: Tom Kerekes Date: 6/26/2016
Hi David,
I don't see anything problematic.
Based on the back-emf spec of 42.75V/KRPM I would expect you to be able to get around 1500RPM with an 80V supply.
On 6/26/2016 8:45 AM, David Stevenson david.m.stevenson@... [DynoMotion] wrote:
Thank you,
David.
Hi David,
REPORT
and axis1:
REPORT
David.
Hi David,
David
Thank you,
David.
Hi David,
[DynoMotion] wrote:
> Thanks Tom.
> to work here.
> software version.
> Regards,
> David.
Group: DynoMotion Message: 13397 From: David Stevenson Date: 6/26/2016
Thank you. 1500 RPM is lots for this application.
David.
On 6/26/2016 12:40 PM, Tom Kerekes tk@... [DynoMotion] wrote:
Hi David,
Thank you,
David.
Hi David,
REPORT
and axis1:
REPORT
David.
Hi David,
David
Thank you,
David.
Hi David,
[DynoMotion] wrote:
> Thanks Tom.
> to work here.
> software version.
> Regards,
> David.
